Replacng rear axle assembly
What you do is find an old king pin. (Other half inch bar is available). Grind a taper about half the length that reduces the diameter down to 3/8 or so over half the length. If inserted from the inner side it will help align the axle with the spring bush. Then insert the pin and push it in, maybe with a hammer and brass drift until the pin is about 1/8 away from the spring bush. Take a deep breath and whack the spring pin with the hammer and drift. It will push the king pin out and the spring pin will be in position. Simples.
Replacng rear axle assembly - by SneezerUSA - 06-11-2021, 05:53 PM
RE: Replacng rear axle assembly - by Chris KC - 06-11-2021, 07:35 PM
RE: Replacng rear axle assembly - by Bob Culver - 06-11-2021, 07:57 PM
RE: Replacng rear axle assembly - by Chris KC - 06-11-2021, 08:09 PM
RE: Replacng rear axle assembly - by Stumpi - 06-11-2021, 08:45 PM
RE: Replacng rear axle assembly - by Alan - 06-11-2021, 09:17 PM
RE: Replacng rear axle assembly - by Bob Culver - 07-11-2021, 05:45 AM
RE: Replacng rear axle assembly - by SneezerUSA - 07-11-2021, 08:59 PM
RE: Replacng rear axle assembly - by Bob Culver - 07-11-2021, 09:16 PM
RE: Replacng rear axle assembly - by SneezerUSA - 08-11-2021, 04:20 PM
RE: Replacng rear axle assembly - by Hedd_Jones - 08-11-2021, 04:57 PM
RE: Replacng rear axle assembly - by SneezerUSA - 09-11-2021, 02:31 AM
RE: Replacng rear axle assembly - by Tony Press - 09-11-2021, 02:40 AM
RE: Replacng rear axle assembly - by SneezerUSA - 09-11-2021, 03:01 AM
RE: Replacng rear axle assembly - by Bob Culver - 09-11-2021, 06:00 AM
RE: Replacng rear axle assembly - by SneezerUSA - 11-11-2021, 11:42 PM
RE: Replacng rear axle assembly - by Bob Culver - 12-11-2021, 01:24 AM
RE: Replacng rear axle assembly - by SneezerUSA - 12-11-2021, 01:34 AM
RE: Replacng rear axle assembly - by SneezerUSA - 12-11-2021, 02:40 AM
RE: Replacng rear axle assembly - by Chris KC - 12-11-2021, 09:08 AM
RE: Replacng rear axle assembly - by SneezerUSA - 12-11-2021, 03:18 PM
