(28-10-2021, 09:42 PM)AustinWood Wrote: If the front tyres are wearing on the outside then the track is probably toe'd in too much.
The tracking is correct. If the toe in was wrong, there would be feathering of the tread and there is none. I used to have exactly the same problem with my Metro Turbo, but on the inside of the tyre because of the negative camber on the front. I think that the problem so far as the Seven goes lies in the fact that modern roads are wider and less cambered than they were in the '30's.
RE: What have you done today with your Austin Seven - by David Stepney - 28-10-2021, 10:03 PM
Users browsing this thread: 22 Guest(s)
