  • 1 Vote(s) - 2 Average
Cold starting
Hi Venn
Mike’s comments about the float chamber draining are pertinent. So do check the seals on the jet and float chamber. Choke control on an H and HS SU has two components, lowering the jet allowing more fuel past the needle …and opening the butterfly slightly.  The throttle component adjustment needs to be set up carefully and once working you shouldn’t need to use the hand control at all.
Good luck
Cold starting - by Venn - 05-10-2021, 10:18 AM
RE: Cold starting - by nrzam - 05-10-2021, 10:34 AM
RE: Cold starting - by Mike Costigan - 05-10-2021, 10:40 AM
RE: Cold starting - by Hugh Barnes - 05-10-2021, 11:05 AM
RE: Cold starting - by andrew34ruby - 05-10-2021, 11:27 AM
RE: Cold starting - by Howard Wright - 05-10-2021, 12:00 PM
RE: Cold starting - by Jeff Taylor - 05-10-2021, 12:08 PM
RE: Cold starting - by Venn - 05-10-2021, 12:58 PM
RE: Cold starting - by Howard Wright - 05-10-2021, 01:18 PM
RE: Cold starting - by Hugh Barnes - 05-10-2021, 01:25 PM
RE: Cold starting - by Malcolm Parker - 05-10-2021, 01:26 PM
RE: Cold starting - by John Cornforth - 05-10-2021, 01:36 PM
RE: Cold starting - by John Mason - 05-10-2021, 04:43 PM
RE: Cold starting - by Chris KC - 05-10-2021, 07:12 PM
RE: Cold starting - by graham - 06-10-2021, 10:31 AM
RE: Cold starting - by David Stepney - 07-10-2021, 08:39 AM
RE: Cold starting - by Hugh Barnes - 07-10-2021, 08:54 AM
RE: Cold starting - by John Mason - 07-10-2021, 09:16 AM
RE: Cold starting - by Hedd_Jones - 07-10-2021, 05:44 PM
RE: Cold starting - by john williams - 08-10-2021, 07:08 PM
RE: Cold starting - by Nick Salmon - 09-10-2021, 07:41 PM
RE: Cold starting - by Roger Goldthorpe - 10-10-2021, 08:50 AM
RE: Cold starting - by Dave Wheatley - 10-10-2021, 09:16 AM
RE: Cold starting - by Roland Alcock - 10-10-2021, 09:16 PM
