Photos for Hedd:
Hopefully these give you sufficient info.
I've measured the hole on the starter nut for the taper pin. It seems to be about 5.9mm one side and 5.6mm the other. However, the fan pulley is an ali version (reproduction?) and may not behave well with the taper pin for the holes drilled in it. That I will have to see as I offer it all up. If anyone has an original steel version they might be prepared to part with, that might be a better option..
Anyone?
RE: What have you done today with your Austin Seven - by Hugh Barnes - 25-09-2021, 10:10 AM
Users browsing this thread: 18 Guest(s)
