Bore wear, engine wear.
We hear that most wear in the bores takes place when the engine is cold, or not up to full running temperature. So, what is best to do over the winter if we don't use the seven so much?
Ten minutes running each fortnight means the engine is wearing out all the time, as it never gets hot. But 30 minutes running each fortnight must cause just as much wear, plus a bit.
Is 30 minutes running once a month better?
Logically 30 minutes running at two month intervals is even less wear?
Bore wear, engine wear. - by andrew34ruby - 22-09-2021, 09:06 PM
RE: Bore wear, engine wear. - by Chris KC - 22-09-2021, 09:38 PM
RE: Bore wear, engine wear. - by Howard Wright - 22-09-2021, 09:58 PM
RE: Bore wear, engine wear. - by Charles P - 22-09-2021, 11:02 PM
RE: Bore wear, engine wear. - by andrew34ruby - 22-09-2021, 11:49 PM
RE: Bore wear, engine wear. - by Bob Culver - 22-09-2021, 11:59 PM
RE: Bore wear, engine wear. - by Colin Reed - 23-09-2021, 03:44 AM
RE: Bore wear, engine wear. - by Chris KC - 23-09-2021, 08:05 AM
RE: Bore wear, engine wear. - by Mike Costigan - 23-09-2021, 09:48 AM
RE: Bore wear, engine wear. - by AustinWood - 23-09-2021, 10:03 AM
RE: Bore wear, engine wear. - by Chris KC - 23-09-2021, 10:21 AM
RE: Bore wear, engine wear. - by John Cornforth - 23-09-2021, 12:40 PM
RE: Bore wear, engine wear. - by Charles P - 23-09-2021, 01:27 PM
RE: Bore wear, engine wear. - by Nick Turley - 23-09-2021, 02:00 PM
RE: Bore wear, engine wear. - by Bob Culver - 23-09-2021, 08:15 PM
RE: Bore wear, engine wear. - by Steve kay - 23-09-2021, 10:06 PM
RE: Bore wear, engine wear. - by Ray White - 23-09-2021, 10:30 PM
RE: Bore wear, engine wear. - by Bob Culver - 23-09-2021, 10:40 PM
RE: Bore wear, engine wear. - by Bob Culver - 24-09-2021, 10:44 AM
RE: Bore wear, engine wear. - by andrew34ruby - 24-09-2021, 06:40 PM
RE: Bore wear, engine wear. - by Tony Griffiths - 24-09-2021, 11:28 PM
RE: Bore wear, engine wear. - by Dave Mann - 25-09-2021, 06:23 PM
