17-09-2021, 11:36 AM
"New Tyres" - Shame the tread pattern doesnt match tho!
Raleigh Chopper Mudguards held on with 1/4 bar and 6mm bolts and a great design feature!
Threaded rod welded onto the throttle linkage -
The wiring looks like a snakes wedding
I do like the coat hooks on the exhaust heat shield - i assume you can use it to dry your hat on!
Why does the number plate cover the starting handle hole - i assume the radiator is to long!!
All that said, it has potential, and if i was looking for a cheep project id be tempted at no mopre than £2k given the problems - but i do fear a novice falls into the trap of buying what appears to be a cheep sporty number thinking they are getting a bargain!
