  • 1 Vote(s) - 1 Average
Gravity tank Petrol Tap seals
I also found the o rings useless, adjusted so you can move the tap they leak and when tightened up to stop leaks you can't move the tap. I prefer the corks however they will shrink and leak if allowed to dry out when the tank is drained, when I drain a tank I pour a cup full of engine oil in the tank to help stop corrosion and to keep the corks moist.
Gravity tank Petrol Tap seals - by David.H - 15-09-2021, 09:41 AM
RE: Gravity tank Petrol Tap seals - by Tony Betts - 15-09-2021, 06:06 PM
RE: Gravity tank Petrol Tap seals - by Dave Mann - 15-09-2021, 08:01 PM
