Clutch Cross Shaft Removal
I am not familiar with the set up but wonder if it is possible to:-
Mig weld something to large end of pin to provide turning/pulling force.  The heat on the pin may even just free the pin as the heat is very localised to the pin.
I used this method on a broken off stud in another car where there was a tiny bit of stud sticking out.  A nut placed over the end and a quick burst of weld on end of stud/inside of nut followed by more weld and the stud just unwound ok.
Dennis
Clutch Cross Shaft Removal - by Chris KC - 05-09-2021, 03:56 PM
RE: Clutch Cross Shaft Removal - by Steve Jones - 05-09-2021, 04:04 PM
RE: Clutch Cross Shaft Removal - by Chris KC - 05-09-2021, 04:05 PM
RE: Clutch Cross Shaft Removal - by Steve Jones - 05-09-2021, 04:09 PM
RE: Clutch Cross Shaft Removal - by Chris KC - 05-09-2021, 04:19 PM
RE: Clutch Cross Shaft Removal - by Steve Jones - 05-09-2021, 04:59 PM
RE: Clutch Cross Shaft Removal - by Jeff Taylor - 05-09-2021, 06:05 PM
RE: Clutch Cross Shaft Removal - by Chris KC - 05-09-2021, 10:15 PM
RE: Clutch Cross Shaft Removal - by Dennis Nicholas - 06-09-2021, 01:00 PM
