05-09-2021, 04:59 PM
(This post was last modified: 05-09-2021, 05:00 PM by Steve Jones.)
The taper pins are 7/32" x 1 1/4" imperial, Chris. Imperial pins are measured at the larger end, metric at the smaller end. To do the job properly, I'd suggest obtaining a 7/32" imperial taper reamer as well to clean up the holes in the cross shaft and levers.
Good luck!!
Good luck!!
