Rough Running - Any Advice
John,
I fitted a pair of Distributor Doctor bushes (about £8.0) I believe.
The shaft was slightly worn so a reamer would have removed too much metal, I used fine wet ‘n dry on a wooden dowel by hand. To remove the old ones I made a washer the correct size with flats on to slide down so that I could pull each bush out in turn.
Fitting them needs care as they are thin in section, best to warm the distributor and freeze the bushes.
Make sure they enter squarely to start with and gently squeeze in place with a vice.
A vast improvement once it was all done well worth the time and effort.
Roger
Rough Running - Any Advice - by John P - 30-08-2021, 04:28 PM
RE: Rough Running - Any Advice - by Dave Wortley - 30-08-2021, 08:59 PM
RE: Rough Running - Any Advice - by Bob Culver - 30-08-2021, 09:42 PM
RE: Rough Running - Any Advice - by John P - 31-08-2021, 04:13 PM
RE: Rough Running - Any Advice - by Roger - 31-08-2021, 10:33 PM
