16-02-2018, 09:39 PM
I used some “press n peel” pcb iron on resist from maplins. Print the inverse of the image using a laser printer and then etched into brass sheet using ferric chloride. I then filled in the etched areas with enamel paint and cut back with wet and dry.
In principle, I could nickel plate the result but I haven’t got around to it.
Peter
Peter
