31-08-2021, 12:27 PM
Photo is a view down - coil, steering box, engine mounting and starter on the left. Speedo cable comes from battery box and passes about 1" away from the starter motor on the way down, held in place by a cable tie onto the thick cable cable going to the starter motor switch. It then disappears down past and under the chassis, just missing the grease nipple on the drag link.
Whether this helps or not remains to be seen.
Don't know if speedo cables for Mk1 and Mk2 Rubys need to be different?
