Help with Ruby front Brakes
Unless going wading the hubs require grease in little more then the bearings. Even with orig bearings definitely not pump hub full. Sealing requirments in the front then very modest. The screws must be distinctly below the surface. Over the years steel shoes get filed to get even seating etc and can get very poor seating when rearranged. Wasteful to abrade shoes to correct major errors. If a good fit origianlly parts best kept in same positon. The steel can be built up with weld and refitted. The steel washer is essential as the bearing must be clamped by the hub halves. Very thick gasket must be avoided.The large bearing should be a snug fit in housing; awkward if not; many been centre dotted....
The rear hub prone to diff oil . A much reduced diff oil level recommended. Sealed bearings and modern seal all assist. But if no sign of diff oil leave alone. Save your sealed bearings and fancy seal for the rear!
Tinkering with rear is more involved and requires breaking the axle taper...another story.
At the rear the screws help stop the flood of diff oil onto the linings whn the wheel removed! Many moderns have no screws despite hydraulic brakes which fail if the wheel and drum detach...
Help with Ruby front Brakes - by DaveT - 28-08-2021, 12:07 PM
RE: Help with Ruby front Brakes - by Hugh Barnes - 28-08-2021, 12:48 PM
RE: Help with Ruby front Brakes - by Ivor Hawkins - 28-08-2021, 02:01 PM
RE: Help with Ruby front Brakes - by DaveT - 28-08-2021, 04:15 PM
RE: Help with Ruby front Brakes - by Reckless Rat - 28-08-2021, 04:32 PM
RE: Help with Ruby front Brakes - by DaveT - 28-08-2021, 04:42 PM
RE: Help with Ruby front Brakes - by DaveT - 28-08-2021, 07:34 PM
RE: Help with Ruby front Brakes - by Reckless Rat - 28-08-2021, 07:38 PM
RE: Help with Ruby front Brakes - by DaveT - 28-08-2021, 07:59 PM
RE: Help with Ruby front Brakes - by DaveT - 30-08-2021, 04:47 PM
RE: Help with Ruby front Brakes - by Bob Culver - 30-08-2021, 08:40 PM
