inner steering column removal hourglass box
Thanks Ian.
For my benefit and others, what is the process to go through to set up the correct end float with the shims on the end plate?
I have a DTI if needed.  My mind just can't fathom out how to go about it with the outers being an interference fit in the box.  I also have a hydraulic press that can be used for pressing out inner column and hence bearings (I don't like idea of block of wood and hammer on steering wheel end having remembered someone's comment some time in the past about removing other bearings about doing similar hammering practice may cause balls to make indents in the races.
Dennis
RE: inner steering column removal hourglass box - by Dennis Nicholas - 23-08-2021, 11:06 AM
