Engine runs, even after switch master cut off
And I have been tellng everyone Seven wiring is simple! Can see the knochen will knock off the volts but cannot fathom the rest. Can anyone explain please?
Coil cars continue to run with the battery disconnected. But the system voltage likely goes far above 6v and will damage bulbs and maybe the coil. Might even start if run downhill.
RE: Engine runs, even after switch master cut off - by Bob Culver - 22-08-2021, 08:39 PM
