Crankshaft bearings
As Tony's post Derek - if you know what bearing came off I'd have a look and see if it's still available (it was obviously working OK).
It might be that someone has taken it to next metric size (in which case it will be a load cheaper too!)
Just a thought but have you checked the outer housing is correct size too?
David, heating bearings and crankshafts locally to 300C is not a great idea.
Crankshaft bearings - by derekn - 18-08-2021, 08:34 PM
RE: Crankshaft bearings - by Chris KC - 18-08-2021, 08:48 PM
RE: Crankshaft bearings - by Howard Wright - 18-08-2021, 09:23 PM
RE: Crankshaft bearings - by Robert Leigh - 18-08-2021, 10:01 PM
RE: Crankshaft bearings - by derekn - 18-08-2021, 10:41 PM
RE: Crankshaft bearings - by Bob Culver - 18-08-2021, 11:42 PM
RE: Crankshaft bearings - by David Stepney - 19-08-2021, 09:23 AM
RE: Crankshaft bearings - by Tony Betts - 19-08-2021, 09:38 AM
RE: Crankshaft bearings - by derekn - 19-08-2021, 10:01 AM
RE: Crankshaft bearings - by Chris KC - 19-08-2021, 11:16 AM
RE: Crankshaft bearings - by John Cornforth - 19-08-2021, 01:59 PM
RE: Crankshaft bearings - by derekn - 19-08-2021, 02:40 PM
RE: Crankshaft bearings - by Bob Culver - 19-08-2021, 08:13 PM
RE: Crankshaft bearings - by Tony Betts - 19-08-2021, 08:59 PM
RE: Crankshaft bearings - by Chris KC - 19-08-2021, 09:56 PM
RE: Crankshaft bearings - by dickie65 - 19-08-2021, 09:59 PM
