Power outputs
#32
(16-08-2021, 03:21 PM)andrew34ruby Wrote:
(15-08-2021, 03:20 PM)dickie65 Wrote: I have been eying up a Kuboto 1500 four cylinder diesel from a generator set in a corner of work.
Its a bit on the large side so a three pot might be better. It would have to pass modern emmisions and be MOT tested though.
I can see that the different engine would mean the car needed an mot, but would that include modern emissions testing standards. I would expect the test to require the relevant standard for that age of car.
I remember reading somewhere in the MOT testers' manual that the emissions test should match the age of the installed motor rather than the car. So if you decided  you really wanted an A7 motor in your Suzuki Jimny, it would only need to pass the "visible smoke" test at the MOT.
In anything other than my rather extreme example, I'm not sure how that might work in practice with a motor that isn't fairly generally recognisable such as a Kubota unit. If you turned up for an MOT and said 'yeah mate Herbert Austin was a very early adopter of Diesel technology, this is one of very few survivors from the factory test program' Big Grin they just might not argue with you....
Power outputs - by Mike Costigan - 11-08-2021, 03:04 PM
RE: Power outputs - by Ian Williams - 11-08-2021, 08:50 PM
RE: Power outputs - by Bob Culver - 11-08-2021, 09:20 PM
RE: Power outputs - by Dave Mann - 11-08-2021, 09:32 PM
RE: Power outputs - by Bob Culver - 12-08-2021, 03:06 AM
RE: Power outputs - by Mike Costigan - 12-08-2021, 08:25 AM
RE: Power outputs - by Tony Griffiths - 12-08-2021, 09:04 AM
RE: Power outputs - by Colin Morgan - 12-08-2021, 09:09 AM
RE: Power outputs - by Colin Reed - 12-08-2021, 10:10 AM
RE: Power outputs - by Eddamoo - 12-08-2021, 10:32 AM
RE: Power outputs - by Mike Costigan - 12-08-2021, 10:45 AM
RE: Power outputs - by David Stepney - 12-08-2021, 12:49 PM
RE: Power outputs - by Colin Morgan - 12-08-2021, 05:28 PM
RE: Power outputs - by Robert Leigh - 12-08-2021, 05:42 PM
RE: Power outputs - by David Stepney - 12-08-2021, 08:03 PM
RE: Power outputs - by Robert Leigh - 12-08-2021, 09:18 PM
RE: Power outputs - by andrew34ruby - 12-08-2021, 09:21 PM
RE: Power outputs - by Bob Culver - 12-08-2021, 10:02 PM
RE: Power outputs - by Ian McGowan - 13-08-2021, 09:58 AM
RE: Power outputs - by AustinWood - 13-08-2021, 11:18 AM
RE: Power outputs - by Bob Culver - 13-08-2021, 10:40 PM
RE: Power outputs - by Bob Culver - 15-08-2021, 05:00 AM
RE: Power outputs - by Hedd_Jones - 15-08-2021, 09:06 AM
RE: Power outputs - by dickie65 - 15-08-2021, 03:20 PM
RE: Power outputs - by Hedd_Jones - 15-08-2021, 05:12 PM
RE: Power outputs - by dickie65 - 15-08-2021, 06:15 PM
RE: Power outputs - by Reckless Rat - 15-08-2021, 07:07 PM
RE: Power outputs - by Colin Morgan - 15-08-2021, 08:15 PM
RE: Power outputs - by Colin Reed - 15-08-2021, 10:57 PM
RE: Power outputs - by andrew34ruby - 16-08-2021, 03:21 PM
RE: Power outputs - by Hedd_Jones - 16-08-2021, 03:40 PM
RE: Power outputs - by Stuart Giles - 17-08-2021, 01:13 PM
