Power outputs
(12-08-2021, 10:10 AM)Colin Reed Wrote: HI All,
I would like to know the TORQUE Figures and at what RPM it levels off at with these Engines,
For me Quoting  Hp is Irrelevant.
Colin
NZ
Colin, it's bhp that matters, but if you want torque it's easy to work it out......   torque x revs = bhp
so.......  torque = bhp/revs
This would give you torque at the revs of max bhp, not max torque, but might be useful.
(11-08-2021, 03:04 PM)Mike Costigan Wrote: Looking at the technical specifications published in sales brochures over the years, the official power output of the Seven is given as follows:
1922-23 10bhp at 2,400 rpm (696cc engine)
1923-32 10.5bhp at 2,400 rpm (747.5cc engine, up-draught carb)
1933-35 10.5bhp at 2,400 rpm (side-draught carb and revised exhaust manifold)
1935-36 13.5bhp at 3,000 rpm (presumably higher-comp 1A684 cylinder head)
1936-38 17bhp at 3,800 rpm (3-bearing engine with high-comp cylinder head)
Which raises a few interesting questions (well, it does to me!).
Did the 7.5% increase in engine capacity in 1923 really only provided a 5% increase in power?
Doesn't the 1933 side-draught carb and associated manifold not provide a bit more power?
If the earlier engines are rev'd to 3,000rpm as quoted for 1935-36, how much more power is achieved?
Similarly, if revs are increased to the 3,800rpm used for the 3-bearing engine, how much more power do the earlier engines produce?
Thoughts, anyone?
I would expect all of those figures to be maximum bhp.  So if an earlier engine was rev'd to 3,000 I would expect the bhp to drop below the quoted 10.5.
Similarly the bhp would drop further if revd to 3,800.
Increasing revs leads to a proportional increase in power if torque stays the same. But torque would be at a maximum at lower revs, maybe 2,000. So increasing revs from say 2,400 to 3,000 would lead to a big decrease in torque, an increase in revs, and a resultant moderate reduction in bhp.
With any engine, what really matters is the bhp at the revs you actually use.
Power outputs - by Mike Costigan - 11-08-2021, 03:04 PM
RE: Power outputs - by Ian Williams - 11-08-2021, 08:50 PM
RE: Power outputs - by Bob Culver - 11-08-2021, 09:20 PM
RE: Power outputs - by Dave Mann - 11-08-2021, 09:32 PM
RE: Power outputs - by Bob Culver - 12-08-2021, 03:06 AM
RE: Power outputs - by Mike Costigan - 12-08-2021, 08:25 AM
RE: Power outputs - by Tony Griffiths - 12-08-2021, 09:04 AM
RE: Power outputs - by Colin Morgan - 12-08-2021, 09:09 AM
RE: Power outputs - by Colin Reed - 12-08-2021, 10:10 AM
RE: Power outputs - by Eddamoo - 12-08-2021, 10:32 AM
RE: Power outputs - by Mike Costigan - 12-08-2021, 10:45 AM
RE: Power outputs - by David Stepney - 12-08-2021, 12:49 PM
RE: Power outputs - by Colin Morgan - 12-08-2021, 05:28 PM
RE: Power outputs - by Robert Leigh - 12-08-2021, 05:42 PM
RE: Power outputs - by David Stepney - 12-08-2021, 08:03 PM
RE: Power outputs - by Robert Leigh - 12-08-2021, 09:18 PM
RE: Power outputs - by andrew34ruby - 12-08-2021, 09:21 PM
RE: Power outputs - by Bob Culver - 12-08-2021, 10:02 PM
RE: Power outputs - by Ian McGowan - 13-08-2021, 09:58 AM
RE: Power outputs - by AustinWood - 13-08-2021, 11:18 AM
RE: Power outputs - by Bob Culver - 13-08-2021, 10:40 PM
RE: Power outputs - by Bob Culver - 15-08-2021, 05:00 AM
RE: Power outputs - by Hedd_Jones - 15-08-2021, 09:06 AM
RE: Power outputs - by dickie65 - 15-08-2021, 03:20 PM
RE: Power outputs - by Hedd_Jones - 15-08-2021, 05:12 PM
RE: Power outputs - by dickie65 - 15-08-2021, 06:15 PM
RE: Power outputs - by Reckless Rat - 15-08-2021, 07:07 PM
RE: Power outputs - by Colin Morgan - 15-08-2021, 08:15 PM
RE: Power outputs - by Colin Reed - 15-08-2021, 10:57 PM
RE: Power outputs - by andrew34ruby - 16-08-2021, 03:21 PM
RE: Power outputs - by Hedd_Jones - 16-08-2021, 03:40 PM
RE: Power outputs - by Stuart Giles - 17-08-2021, 01:13 PM
