Power outputs
(12-08-2021, 10:32 AM)Eddamoo Wrote: ...  I cant imagine a '22-'34 engine topping out so early, especially given Mike's response.
If I was to change up from second to top at 2,400 rpm, that would be around 20mph; at that speed the engine is only just getting into its stride, and by the time top gear is engaged the engine doesn't have enough power to pull the skin off the proverbial rice pudding!
Edit: I should add that the engine is to entirely standard 1931 specification.
Power outputs - by Mike Costigan - 11-08-2021, 03:04 PM
RE: Power outputs - by Ian Williams - 11-08-2021, 08:50 PM
RE: Power outputs - by Bob Culver - 11-08-2021, 09:20 PM
RE: Power outputs - by Dave Mann - 11-08-2021, 09:32 PM
RE: Power outputs - by Bob Culver - 12-08-2021, 03:06 AM
RE: Power outputs - by Mike Costigan - 12-08-2021, 08:25 AM
RE: Power outputs - by Tony Griffiths - 12-08-2021, 09:04 AM
RE: Power outputs - by Colin Morgan - 12-08-2021, 09:09 AM
RE: Power outputs - by Colin Reed - 12-08-2021, 10:10 AM
RE: Power outputs - by Eddamoo - 12-08-2021, 10:32 AM
RE: Power outputs - by Mike Costigan - 12-08-2021, 10:45 AM
RE: Power outputs - by David Stepney - 12-08-2021, 12:49 PM
RE: Power outputs - by Colin Morgan - 12-08-2021, 05:28 PM
RE: Power outputs - by Robert Leigh - 12-08-2021, 05:42 PM
RE: Power outputs - by David Stepney - 12-08-2021, 08:03 PM
RE: Power outputs - by Robert Leigh - 12-08-2021, 09:18 PM
RE: Power outputs - by andrew34ruby - 12-08-2021, 09:21 PM
RE: Power outputs - by Bob Culver - 12-08-2021, 10:02 PM
RE: Power outputs - by Ian McGowan - 13-08-2021, 09:58 AM
RE: Power outputs - by AustinWood - 13-08-2021, 11:18 AM
RE: Power outputs - by Bob Culver - 13-08-2021, 10:40 PM
RE: Power outputs - by Bob Culver - 15-08-2021, 05:00 AM
RE: Power outputs - by Hedd_Jones - 15-08-2021, 09:06 AM
RE: Power outputs - by dickie65 - 15-08-2021, 03:20 PM
RE: Power outputs - by Hedd_Jones - 15-08-2021, 05:12 PM
RE: Power outputs - by dickie65 - 15-08-2021, 06:15 PM
RE: Power outputs - by Reckless Rat - 15-08-2021, 07:07 PM
RE: Power outputs - by Colin Morgan - 15-08-2021, 08:15 PM
RE: Power outputs - by Colin Reed - 15-08-2021, 10:57 PM
RE: Power outputs - by andrew34ruby - 16-08-2021, 03:21 PM
RE: Power outputs - by Hedd_Jones - 16-08-2021, 03:40 PM
RE: Power outputs - by Stuart Giles - 17-08-2021, 01:13 PM
