11-08-2021, 10:07 AM
(This post was last modified: 11-08-2021, 01:41 PM by darcher121.)
Really useful pictures, thank you so much.
I have had to remanufacture the contact strip as the original had broken in half. It will need some fettling to get just right.
Also, it would appear that my handle doesn’t come out far enough.
Does the handle shaft slide within the spinning motor block? Mine is fixed (or stuck) so any in/out movement of the handle also moves the block up and down.
I have removed the screw from the head of the plastic knob but it won’t come off. Shouldn't it just slide off? Mine has a small split in it so I suspect there is some corrosion and don’t want to completely break the knob.
