Use of gaskets
Hi All
Up until now I’ve generally used paper gaskets supplied by one or other of the cherished suppliers. I’ve followed Woodrow in where they should go and used a smear of blue hylomar on both sides. That is apart from the block to case and sump where I’m an advocate of the silicon ones applied dry.
However I seem to remember reading that some members don’t use gaskets but rely on gasket cement alone.
What do forum members think of omitting gaskets? If you don’t use gaskets what “goo” do you put between the surfaces?
Use of gaskets - by Howard Wright - 09-08-2021, 07:39 PM
RE: Use of gaskets - by Andy Bennett - 09-08-2021, 08:17 PM
RE: Use of gaskets - by Howard Wright - 09-08-2021, 08:36 PM
RE: Use of gaskets - by JonE - 09-08-2021, 08:52 PM
RE: Use of gaskets - by Chris KC - 09-08-2021, 09:21 PM
RE: Use of gaskets - by Tony Press - 09-08-2021, 11:40 PM
RE: Use of gaskets - by Bob Culver - 10-08-2021, 02:23 AM
