It takes about 20 minutes to get the engine out and maybe an hour to put it back in, if you are in practice. Probably takes longer than that to work out a way to undo the back block stud, and then you have the conrods to undo from underneath or the pistons to ease back into the block. Honest guys taking the engine out is the easy solution
