block to crankcase joint - external seal?
#29
It's much easier to work on the engine with it on the bench rather than in the car. Fitting a silicone gasket is dependant on clean mating surfaces. If not, then it will leak like any other. The engine on my RP used to leak oil like a sieve until it was rebuilt in 2019. It is now to all intents and purposes, oil tight.
ish
RE: block to crankcase joint - external seal? - by Reckless Rat - 06-08-2021, 05:15 PM
