  • 1 Vote(s) - 4 Average
Coolant
The information on the web suggests that Fernox F1 should be right for iron and aluminium. Possibly your water in that area is soft with a relatively low pH. I suggest that distilled water is best. Water from a dehuidifier is effectively just that, or you can use water from defrosting the fridge or freezer. If the deposit is soft as you say, power flushing with a hose alternately in each engine connection on an annual basis will probably clear the system usefully. I have to admit that I do not worry unduly about my cooling systems unles there are signs of a problem.
Coolant - by Steve kay - 06-08-2021, 08:26 AM
RE: Coolant - by Robert Leigh - 06-08-2021, 09:42 AM
RE: Coolant - by Eddamoo - 06-08-2021, 11:03 AM
RE: Coolant - by circeonya@hotmail.com - 06-08-2021, 11:13 AM
RE: Coolant - by Russlin - 06-08-2021, 01:44 PM
RE: Coolant - by Bob Culver - 07-08-2021, 03:42 AM
RE: Coolant - by Chris KC - 07-08-2021, 08:42 AM
