Standard Roller Bering Clearances
(04-08-2021, 01:55 PM)jr2766 Wrote: Thanks for taking the time to respond Tony
I was hoping the community had some firm guidlines because I have heard a couple of recently rebuilt engines and while I understand there are a lot of variables I'd be very disappointed to achieve such an outcome.
runcimans@westnet.com.au
As I always advise- only buy genuine bearings and not the cheaper Chinese copies, often readily available and in genuine looking packaging.
From my experience there are still a few original stock SKF or R&M imperial bearings around - most likely with normal clearance. May be not the cheapest but well worth it.
If you do happen on a Three Dot or C3 it should be ok but I wouldn't use a Two Dot or C2.
I do not know what rolling bearing shaft tolerances Phoenix cranks manufacture to- engine builders should check to see if over tight.
Standard Roller Bering Clearances - by jr2766 - 28-07-2021, 02:07 AM
RE: Standard Roller Bering Clearances - by jr2766 - 30-07-2021, 01:57 PM
RE: Standard Roller Bering Clearances - by jr2766 - 04-08-2021, 01:55 PM
RE: Standard Roller Bering Clearances - by Tony Press - 05-08-2021, 12:13 AM
