04-08-2021, 10:56 AM
Still having the same issue I thought I replaced the pump spring but the diaphragm did not come with a new spring,replaced thr old diaphragm and tried again still flooding badly, needle jet does not pass when blowing through it will try more washers under the needle valve, does the fuel cut off rely on the floated needle vale or does it resurculate within the pump also somehow?
