Standard Roller Bering Clearances
Some time ago someone publshed here a 1929 crank blueprint which gave journal tolerances as front -.00025 and rear + .00025
Used with the bearing tolerance Tony quotes would help explain why so many rear mains worked loose. The tolerances i quoted also appear in Machinery Handbook 1996. Neither that book or NSK Manual lists specifically for imperial and as NSK make both presumably the same tplerance applies to all.
I dunno how Phoenix are finished but if more than +.00025 any C3 clearances would be reduced
C3 bearings are preferred where a lot of deflection occurs ie 3/4 and semi floating rear wheel bearings. (Contrary to preloading a/c where deflection occurs!)
NSK recommend interference does not exceed 7/10000 of shaft dia.
Standard Roller Bering Clearances - by jr2766 - 28-07-2021, 02:07 AM
RE: Standard Roller Bering Clearances - by jr2766 - 30-07-2021, 01:57 PM
RE: Standard Roller Bering Clearances - by Bob Culver - 03-08-2021, 12:14 AM
RE: Standard Roller Bering Clearances - by jr2766 - 04-08-2021, 01:55 PM
