01-08-2021, 12:43 PM
Setting the timing on an Austin Seven is not an exact science and the "sweet spot" varies from car to car. Static timing, using the flywheel marks is OK as a starting point but it's best to do final adjustments on the road. The ideal is to advance just to the point where the crank begins to rumble, and then back it off a tad. This can be difficult to assess with the High Compression head as it does make the engine sound/feel harsh even though it's not. I would have thought that your car, properly set up should be able to take most hills in 3rd gear, apart from really steep stuff.
It may also be worthwhile checking that the auto advance mechanism under the contact breaker is working correctly in your distributor. If it is seized or faulty then you could be running retarded at higher RPM.
