Clutch judder
The clutch on my special has been developing a judder when changing down and also getting increasingly sharp when taking off from rest. Over the past few hundred miles it has become almost intolerable.
When I heard debris being hurled around in the flywheel area I took the gearbox out expecting to find something obviously amiss however everything looks fine. Apart from a couple of thou movement in the rivets holding the splined boss I can find nothing wrong at all. Incidentally the pinion bearings are newish and the UJs look good. I haven't yet taken the flywheel off and haven't found the debris.
It's a 4 speed box and the clutch-type with linings on the flywheel and cover plate.
Where should I be looking for wear or problems? Clutch levers perhaps?
Clutch judder - by Peter Naulls - 31-07-2021, 02:27 PM
RE: Clutch judder - by Howard Wright - 31-07-2021, 06:48 PM
RE: Clutch judder - by Peter Naulls - 01-08-2021, 05:48 PM
RE: Clutch judder - by Bob Culver - 03-08-2021, 01:59 AM
RE: Clutch judder - by Peter Naulls - 03-08-2021, 08:26 PM
