30-07-2021, 05:56 PM
(This post was last modified: 30-07-2021, 06:01 PM by Duncan Grimmond.)
Ruairidh, I'd love to make you one in tinplate if I could get some dimensions! The angle of the wing would be a start, but I'd also need the width of the base and top as it seems to taper upwards slightly(?) length along the wing and height from the lower edge.
I can't see a stiffener but there is a slight tip around the circumference just below the seam which I imagine will go under the edge of the top panel.
