28-07-2021, 03:55 PM
One fixed thrust block actually had a hole in it at the bottom where ball of pin had worn through so have decided all new Draglink Kit = 2 ball pins, 2 fixed thrust blocks, 2 loose thrust blocks. , 2 springs and 2 slotted nuts.
From The Seven Workshop.
Dimensions:-
Ball diameter o.557 inch, spring length 0.7 inch
Thrust blocks diameter 0.628 inch - length 0.8115 inch.
Dimensions:-
