Rear brakes. Brke shoe pivot point
Hi John
If you use Parazine’s excellent repair idea and you can get the old pivot out then you might not have to remove the hub.
Otherwise that half shaft nut will have to come off and on reassembly be tightened up to within an inch of its life and a few miles later tightened again.
RE: Rear brakes. Brke shoe pivot point - by Howard Wright - 28-07-2021, 10:51 AM
