Rear brakes. Brke shoe pivot point
If you have any mates with a lathe it is a simple task to make, including oversize to maintain the force fit, and threaded if desired. The bore can be sorted with a reamer or perhaps a drill aplied carefully. Material is the problem. Have to be tough. A HT bolt may nor suffice. The softer versions of old back axles suitable. Readily available! Replaced on my car eons ago with ones made from Model T axle.
RE: Rear brakes. Brke shoe pivot point - by Bob Culver - 26-07-2021, 08:51 PM
