Oval backplate stub axles.
Back in July 2020 I asked:
Can one of our experts advise the correct outside diameter of the standard King Pin Bushes  BL 7 and BL 8
The size measured from old bushes-
Lower flanged Bush BL 7: OD 16.2 mm (41/64" ?)
Upper plain Bush BL 8: OD 17.40 mm (11/16" ?)
Measuring our Club stock bushes
Lower flanged bush 17.46 mm
Lower flanged bush16.20 mm
Upper plain bush 17.44 mm
There was no reply to my question so I took the dimensions to be:
Lower flanged Bush BL 7  OD 16.2 mm (41/64")
Upper plain Bush BL 8   OD 17.40 mm (11/16")
Now from the above comments it appears that BL7 and BL8 should both be
Upper and lower Bush BL 7 and BL 8: OD 17.40 mm (11/16")
During 1936, with the new stub axles the bushes became:
Lower flanged Bush 1A4129 OD 16.2 mm (41/64")
Upper plain Bush 1A4128  OD 17.40 mm (11/16")
 Is this correct ?
Oval backplate stub axles. - by Robert Foreman - 23-07-2021, 08:36 PM
RE: Oval backplate stub axles. - by bystander - 23-07-2021, 09:25 PM
RE: Oval backplate stub axles. - by Tony Press - 24-07-2021, 02:44 AM
