Prop shaft noise
The parts illustration is for an early model and differs in details. Complete removal is a bit of a saga; mention if contemplating. There may be scope forĀ trapping leather, plastic, nylon strip or stringĀ as in a tap or water punp gland but risk of blocking the grease/oil hole top and bottom, although once greased the lower ball probably OK
Incidentally, though it appears in many publications, the rear hub section is worth downloading. Very many questions on here can be largely answered by close scrutiny.
Prop shaft noise - by Captain Mike - 23-07-2021, 08:45 AM
RE: Prop shaft noise - by Howard Wright - 23-07-2021, 09:05 AM
RE: Prop shaft noise - by Bob Culver - 23-07-2021, 09:25 AM
RE: Prop shaft noise - by Terry McGrath - 23-07-2021, 12:14 PM
RE: Prop shaft noise - by Reckless Rat - 23-07-2021, 01:15 PM
RE: Prop shaft noise - by Captain Mike - 23-07-2021, 03:05 PM
RE: Prop shaft noise - by Reckless Rat - 23-07-2021, 03:24 PM
RE: Prop shaft noise - by Bob Culver - 24-07-2021, 01:55 AM
RE: Prop shaft noise - by Ivor Hawkins - 24-07-2021, 08:23 PM
RE: Prop shaft noise - by Tony Press - 24-07-2021, 11:17 PM
RE: Prop shaft noise - by Captain Mike - 26-07-2021, 10:15 AM
RE: Prop shaft noise - by Captain Mike - 29-07-2021, 03:09 PM
