Prop shaft noise
Mike, try adjusting the smaller ball joint underneath first. You can put a washer in as a shim to take up any slack. It should be tight but not too tight. Remedial work to the large spherical joint is not an easy fix. You could try removing the locking bolts and tapping the castellated nut clockwise to tighten it, but as already stated there may be no more adjustment left. Attending to the chassis crossmember mounting first may well solve or reduce your cloning to an acceptable level. Good luck.
Prop shaft noise - by Captain Mike - 23-07-2021, 08:45 AM
RE: Prop shaft noise - by Howard Wright - 23-07-2021, 09:05 AM
RE: Prop shaft noise - by Bob Culver - 23-07-2021, 09:25 AM
RE: Prop shaft noise - by Terry McGrath - 23-07-2021, 12:14 PM
RE: Prop shaft noise - by Reckless Rat - 23-07-2021, 01:15 PM
RE: Prop shaft noise - by Captain Mike - 23-07-2021, 03:05 PM
RE: Prop shaft noise - by Reckless Rat - 23-07-2021, 03:24 PM
RE: Prop shaft noise - by Bob Culver - 24-07-2021, 01:55 AM
RE: Prop shaft noise - by Ivor Hawkins - 24-07-2021, 08:23 PM
RE: Prop shaft noise - by Tony Press - 24-07-2021, 11:17 PM
RE: Prop shaft noise - by Captain Mike - 26-07-2021, 10:15 AM
RE: Prop shaft noise - by Captain Mike - 29-07-2021, 03:09 PM
