Captain Tolley's Creeping Crack Cure
Hi Nick
I’ve used this to seal caravan windows (rubber against fibreglass).  Worked very well.  Although if the leak is large you will loose a lot of fluid and need to reapply several times.  Best used when the leak is just a weep rather than a flood  Smile.
RE: Captain Tolley's Creeping Crack Cure - by Howard Wright - 22-07-2021, 03:35 PM
