Steve, are you sure it is block to crankcase joint? I fitted a rear main bearing lip seal on my RN and made a silly mistake when I removed the engine to find the seal retainer housing cracked due to my hamfistedness in assembly. You probably have eliminated cove plate over oil pump shaft and leaky valve cover.
RE: What have you done today with your Austin Seven - by Dave Wortley - 22-07-2021, 11:48 AM
