  • 3 Vote(s) - 4 Average
Building a Special Body
#39
In earlier pictures you will have noticed that I had a solid diaphragm behind the seat, this was there to act both as a stiffer and as a firewall because I intended to have the fuel tank behind me. This presented a bit of a problem as the only access would be through the boot/spare wheel slot and a 2 gallon fuel tank was about all that would fit. I decided that I needed access behind the seat but also wanted to retain some strength and a fire wall, I decided to cut out the centre of the diaphragm and form a swage around the edge in order that I could fit a removable panel. The following series of pictures show how I went about creating this swage, I made a former in MDF with a clamping piece cut from a scrap of ply above, the edge can then be simply dressed down into the former. I have not found it nesecarry to anneal small swages like this as you are not moving much metal, care is needed though not to bruise the panel when when working it.
.jpg   DSC06382.JPG (Size: 221.05 KB / Downloads: 809)
.jpg   DSC06383.JPG (Size: 232.68 KB / Downloads: 808)
.jpg   DSC06384.JPG (Size: 229.31 KB / Downloads: 801)
.jpg   DSC06385.JPG (Size: 245.49 KB / Downloads: 803)
.jpg   DSC06386.JPG (Size: 175.41 KB / Downloads: 801)
.jpg   DSC06387.JPG (Size: 237.41 KB / Downloads: 805)
Building a Special Body - by Ian Williams - 12-10-2017, 03:46 AM
RE: Building a Special Body - by Charles P - 12-10-2017, 08:14 AM
RE: Building a Special Body - by Ruairidh Dunford - 12-10-2017, 08:44 AM
RE: Building a Special Body - by Dave Wortley - 12-10-2017, 09:42 AM
RE: Building a Special Body - by Ruairidh Dunford - 12-10-2017, 10:00 AM
RE: Building a Special Body - by Ian Williams - 12-10-2017, 10:07 AM
RE: Building a Special Body - by Mark Atkinson - 12-10-2017, 09:04 PM
RE: Building a Special Body - by Timothy P - 12-10-2017, 10:54 PM
RE: Building a Special Body - by Erich - 14-10-2017, 03:23 PM
RE: Building a Special Body - by Ian Williams - 15-10-2017, 03:46 AM
RE: Building a Special Body - by Ian Williams - 01-11-2017, 01:52 AM
RE: Building a Special Body - by Erich - 01-11-2017, 05:02 PM
RE: Building a Special Body - by Duncan Grimmond - 01-11-2017, 05:28 PM
RE: Building a Special Body - by Ian Williams - 01-11-2017, 08:03 PM
RE: Building a Special Body - by Duncan Grimmond - 01-11-2017, 10:00 PM
RE: Building a Special Body - by Ian Williams - 01-11-2017, 11:09 PM
RE: Building a Special Body - by Erich - 01-11-2017, 11:55 PM
RE: Building a Special Body - by Ian Williams - 02-11-2017, 03:38 AM
RE: Building a Special Body - by Timothy P - 02-11-2017, 05:43 PM
RE: Building a Special Body - by Ian Williams - 02-11-2017, 08:03 PM
RE: Building a Special Body - by Timothy P - 02-11-2017, 08:43 PM
RE: Building a Special Body - by Duncan Grimmond - 03-11-2017, 09:42 AM
RE: Building a Special Body - by Albert S - 04-11-2017, 09:56 AM
RE: Building a Special Body - by Ian Williams - 04-11-2017, 08:49 PM
RE: Building a Special Body - by Ian Williams - 06-02-2018, 08:58 PM
RE: Building a Special Body - by JonE - 06-02-2018, 11:30 PM
RE: Building a Special Body - by Erich - 07-02-2018, 04:53 AM
RE: Building a Special Body - by merlinart - 07-02-2018, 10:17 AM
RE: Building a Special Body - by Ian Williams - 09-02-2018, 09:14 PM
RE: Building a Special Body - by John Bonnett - 11-02-2018, 09:59 AM
RE: Building a Special Body - by Ian Williams - 11-02-2018, 09:07 PM
RE: Building a Special Body - by Nick Turley - 11-02-2018, 02:36 PM
RE: Building a Special Body - by Duncan Grimmond - 11-02-2018, 04:29 PM
RE: Building a Special Body - by John Bonnett - 12-02-2018, 08:46 AM
RE: Building a Special Body - by cardiffrob - 12-02-2018, 09:00 AM
RE: Building a Special Body - by Ian Williams - 12-02-2018, 09:26 AM
RE: Building a Special Body - by cardiffrob - 12-02-2018, 09:42 AM
RE: Building a Special Body - by Ian Williams - 12-02-2018, 10:02 AM
RE: Building a Special Body - by cardiffrob - 12-02-2018, 11:06 AM
RE: Building a Special Body - by Ian Williams - 12-02-2018, 10:49 PM
RE: Building a Special Body - by Charles P - 13-02-2018, 07:07 AM
RE: Building a Special Body - by Ian Williams - 20-02-2018, 01:45 AM
RE: Building a Special Body - by John Bonnett - 20-02-2018, 08:44 AM
RE: Building a Special Body - by Ian Williams - 20-02-2018, 08:09 PM
RE: Building a Special Body - by Ian Williams - 30-06-2018, 12:43 AM
RE: Building a Special Body - by Jamie - 30-06-2018, 08:49 AM
RE: Building a Special Body - by jansens - 02-07-2018, 06:44 PM
RE: Building a Special Body - by Duncan Grimmond - 02-07-2018, 07:20 PM
RE: Building a Special Body - by jansens - 03-07-2018, 12:19 AM
RE: Building a Special Body - by Ian Williams - 03-07-2018, 08:53 AM
RE: Building a Special Body - by Belinni - 08-04-2019, 12:37 PM
RE: Building a Special Body - by Ian Williams - 08-04-2019, 08:35 PM
RE: Building a Special Body - by squeak - 09-04-2019, 12:40 AM
RE: Building a Special Body - by Timothy P - 09-04-2019, 09:49 AM
RE: Building a Special Body - by Mark Atkinson - 09-04-2019, 10:07 AM
RE: Building a Special Body - by Belinni - 10-04-2019, 12:52 PM
RE: Building a Special Body - by Ian Williams - 18-05-2019, 05:54 AM
RE: Building a Special Body - by DavidL - 19-05-2019, 04:58 PM
RE: Building a Special Body - by Jays - 19-05-2019, 08:47 PM
RE: Building a Special Body - by Ian Williams - 20-05-2019, 05:03 AM
RE: Building a Special Body - by Ian Williams - 17-07-2019, 05:43 AM
RE: Building a Special Body - by Howard Wright - 17-07-2019, 07:37 AM
RE: Building a Special Body - by Ian Williams - 17-07-2019, 09:25 PM
RE: Building a Special Body - by Tony Press - 18-07-2019, 07:45 AM
RE: Building a Special Body - by Ian Williams - 23-07-2019, 03:05 AM
RE: Building a Special Body - by JonE - 23-07-2019, 08:45 PM
RE: Building a Special Body - by Ian Williams - 23-07-2019, 09:39 PM
RE: Building a Special Body - by Jamie - 24-07-2019, 07:34 AM
RE: Building a Special Body - by goodwoodweirdo - 24-07-2019, 02:53 PM
RE: Building a Special Body - by Ian Williams - 24-07-2019, 09:34 PM
RE: Building a Special Body - by Ian Williams - 26-07-2019, 04:34 AM
RE: Building a Special Body - by goodwoodweirdo - 29-07-2019, 03:50 PM
RE: Building a Special Body - by Chris KC - 05-08-2019, 08:21 PM
RE: Building a Special Body - by Ian Williams - 15-08-2019, 02:27 AM
RE: Building a Special Body - by Howard Wright - 15-08-2019, 07:23 AM
RE: Building a Special Body - by Ian Williams - 15-08-2019, 08:09 AM
RE: Building a Special Body - by Ian Williams - 24-08-2019, 09:52 PM
RE: Building a Special Body - by Ian Williams - 31-08-2019, 04:38 AM
RE: Building a Special Body - by Duncan Grimmond - 31-08-2019, 08:20 AM
RE: Building a Special Body - by Steve Bryant - 31-08-2019, 02:00 PM
RE: Building a Special Body - by wild_willy - 01-09-2019, 01:18 AM
RE: Building a Special Body - by Ian Williams - 01-09-2019, 01:52 AM
RE: Building a Special Body - by Jeff Taylor - 01-09-2019, 11:21 AM
RE: Building a Special Body - by David.H - 01-09-2019, 11:35 AM
RE: Building a Special Body - by wild_willy - 01-09-2019, 12:43 PM
RE: Building a Special Body - by Ian Williams - 01-12-2019, 02:14 AM
RE: Building a Special Body - by Paul N-M - 01-12-2019, 02:13 PM
RE: Building a Special Body - by Steve Bryant - 02-12-2019, 02:56 PM
RE: Building a Special Body - by sebring115 - 02-12-2019, 04:13 PM
RE: Building a Special Body - by Ian Williams - 03-12-2019, 08:35 PM
RE: Building a Special Body - by Peter Naulls - 03-12-2019, 10:07 PM
RE: Building a Special Body - by vintage_racing - 04-12-2019, 09:55 AM
RE: Building a Special Body - by Ian Williams - 04-12-2019, 08:05 PM
RE: Building a Special Body - by Peter Naulls - 04-12-2019, 09:35 PM
RE: Building a Special Body - by sebring115 - 05-12-2019, 11:03 AM
RE: Building a Special Body - by Renaud - 08-12-2019, 01:43 PM
RE: Building a Special Body - by Ian Williams - 08-12-2019, 08:52 PM
RE: Building a Special Body - by Renaud - 10-12-2019, 06:44 PM
RE: Building a Special Body - by Ian Williams - 10-12-2019, 07:46 PM
RE: Building a Special Body - by Reckless Rat - 10-12-2019, 08:45 PM
RE: Building a Special Body - by Renaud - 11-12-2019, 09:24 AM
RE: Building a Special Body - by Reckless Rat - 11-12-2019, 11:54 AM
RE: Building a Special Body - by Ian Williams - 11-12-2019, 11:46 PM
RE: Building a Special Body - by Duncan Grimmond - 12-12-2019, 03:15 PM
RE: Building a Special Body - by Renaud - 12-12-2019, 06:43 PM
RE: Building a Special Body - by Charles P - 12-12-2019, 07:34 PM
RE: Building a Special Body - by Reckless Rat - 12-12-2019, 08:29 PM
RE: Building a Special Body - by Ian Williams - 12-12-2019, 10:40 PM
RE: Building a Special Body - by Reckless Rat - 13-12-2019, 08:55 AM
RE: Building a Special Body - by Steve Bryant - 13-12-2019, 03:51 PM
RE: Building a Special Body - by Ian Williams - 13-01-2020, 01:17 AM
RE: Building a Special Body - by Duncan Grimmond - 13-01-2020, 09:09 AM
RE: Building a Special Body - by Hentzant - 13-01-2020, 11:20 AM
RE: Building a Special Body - by Duncan Grimmond - 13-01-2020, 07:00 PM
RE: Building a Special Body - by jansens - 15-01-2020, 07:51 PM
RE: Building a Special Body - by Ian Williams - 24-01-2020, 10:17 AM
RE: Building a Special Body - by Ian Williams - 26-01-2020, 08:07 AM
RE: Building a Special Body - by Duncan Grimmond - 27-01-2020, 09:21 AM
RE: Building a Special Body - by Tony Betts - 27-01-2020, 11:41 AM
RE: Building a Special Body - by jansens - 27-01-2020, 09:25 PM
RE: Building a Special Body - by Ian Williams - 27-01-2020, 09:25 PM
RE: Building a Special Body - by Renaud - 28-01-2020, 07:34 AM
RE: Building a Special Body - by jansens - 28-01-2020, 08:04 AM
RE: Building a Special Body - by Bobski - 28-01-2020, 10:25 AM
RE: Building a Special Body - by Charles P - 28-01-2020, 12:03 PM
RE: Building a Special Body - by Paul N-M - 28-01-2020, 06:37 PM
RE: Building a Special Body - by Ian Williams - 28-01-2020, 09:05 PM
RE: Building a Special Body - by Renaud - 30-01-2020, 07:22 PM
RE: Building a Special Body - by Ian Williams - 30-01-2020, 07:42 PM
RE: Building a Special Body - by Ian Williams - 05-04-2020, 03:55 AM
RE: Building a Special Body - by Spex - 05-04-2020, 06:24 AM
RE: Building a Special Body - by Ian Williams - 05-04-2020, 08:07 AM
RE: Building a Special Body - by Renaud - 05-04-2020, 08:19 AM
RE: Building a Special Body - by Ian Williams - 10-04-2020, 02:29 AM
RE: Building a Special Body - by Renaud - 10-04-2020, 12:44 PM
RE: Building a Special Body - by flywheel1935 - 10-04-2020, 01:05 PM
RE: Building a Special Body - by Paul N-M - 11-04-2020, 08:34 AM
RE: Building a Special Body - by flywheel1935 - 11-04-2020, 10:19 AM
RE: Building a Special Body - by Paul N-M - 11-04-2020, 10:59 AM
RE: Building a Special Body - by Peter Sweeney - 11-04-2020, 11:30 AM
RE: Building a Special Body - by Cliff Ringrose - 11-04-2020, 04:10 PM
RE: Building a Special Body - by Ian Williams - 14-04-2020, 07:03 AM
RE: Building a Special Body - by flywheel1935 - 14-04-2020, 11:08 AM
RE: Building a Special Body - by Bruce Nicholls - 16-04-2020, 05:06 PM
RE: Building a Special Body - by Ian Williams - 21-04-2020, 01:51 AM
RE: Building a Special Body - by Tony Press - 21-04-2020, 02:15 AM
RE: Building a Special Body - by Renaud - 21-04-2020, 07:26 AM
RE: Building a Special Body - by Ian Williams - 21-04-2020, 10:39 AM
RE: Building a Special Body - by Renaud - 21-04-2020, 12:57 PM
RE: Building a Special Body - by Ian Williams - 23-04-2020, 02:57 AM
RE: Building a Special Body - by Ivor Hawkins - 23-04-2020, 08:39 AM
RE: Building a Special Body - by Ian Williams - 24-04-2020, 11:11 PM
RE: Building a Special Body - by Ian Williams - 25-04-2020, 05:12 AM
RE: Building a Special Body - by jpsmit - 25-04-2020, 02:35 PM
RE: Building a Special Body - by Peter Naulls - 25-04-2020, 09:43 PM
RE: Building a Special Body - by Ian Williams - 25-04-2020, 09:56 PM
RE: Building a Special Body - by Steve Bryant - 01-01-2023, 11:21 PM
RE: Building a Special Body - by Ian Williams - 02-01-2023, 08:10 AM
