Aluminium front backplate problems
The lack of Ackermann steering setup on a Seven doesn't seem to make any difference a lack of caster angle or incorrect toe in does. You need 6 to 8 degrees of castor and  1/8"toe in, fitting standard steering track arms facing forward means you can use a straight track rod, it's also advisable to fit tie rods and drop links to radius arms to prevent axle twist with hydraulic brakes.
RE: Aluminium front backplate problems - by Terrytuned - 16-07-2021, 11:58 AM
