block to crankcase joint - external seal?
Re, snipping, I would have thought that any structural elements that keep the sheet from distorting were vital, for IF oil penetrates on less flat surfaces and makes it skate about. Would you be able to get the surfaces properly oil free clean with the slight block lift?
RE: block to crankcase joint - external seal? - by JonE - 15-07-2021, 04:49 PM
