2 bearing Ruby engine - Gudgeon Pins
Unless there is a ring of varnish Seven pins should not be tight. Otherwise on a very cold start the pin tends to loosen.
(Stephen Hainsworth covered this at length some time ago).Where are, and on other makes, I just sit an old household iron on the top for a while. You may not be popular using the good one.
RE: 2 bearing Ruby engine - Gudgeon Pins - by Bob Culver - 30-06-2021, 08:52 PM
