RP engine out
I have little or no problem with the blind spline on re assembly. Put the engine in and line up with the gearbox. From underneath put a Jack under the bell housing and Jack up until the gear box is at the same angle as the engine ( Both on the same plane) gently turn the engine with the the handle at the same time gently rocking the engine. When the blind spline lines up you will feel the engine engage and a difference in the Handle turning.
John Mason.
RP engine out - by richard wyatt - 30-06-2021, 01:24 PM
RE: RP engine out - by Reckless Rat - 30-06-2021, 01:33 PM
RE: RP engine out - by David Stepney - 30-06-2021, 02:38 PM
RE: RP engine out - by Ray White - 30-06-2021, 02:50 PM
RE: RP engine out - by Reckless Rat - 30-06-2021, 03:02 PM
RE: RP engine out - by Chris KC - 30-06-2021, 03:59 PM
RE: RP engine out - by John Mason - 30-06-2021, 04:21 PM
RE: RP engine out - by Martin Prior - 30-06-2021, 04:37 PM
RE: RP engine out - by Tony Press - 30-06-2021, 11:34 PM
RE: RP engine out - by Duncan Grimmond - 30-06-2021, 11:50 PM
RE: RP engine out - by Hugh Barnes - 01-07-2021, 03:56 PM
RE: RP engine out - by richard wyatt - 11-07-2021, 05:11 PM
RE: RP engine out - by Reckless Rat - 11-07-2021, 05:32 PM
