09-02-2018, 09:17 PM
with all these repro AT201s using stop and tail function, what do people do with earthing? Run a three core wire and earth at the metal at the base of the unit, as presumably you can't achieve earth return wire running into the unit itself?
And for retrofitting brake lights on earlier chassis, is anything else needed other than the brake stop switch? https://www.theaustinsevenworkshop.com/p...amp-switch
I'm still unsure what proportion of owners are staying with the smaller faceted-glass units and which are changing to the bigger, legal but less vintage-looking ones! Did anyone to the latter and regret it?
thanks...
thanks...
