Window regulator- 1930 Mulliner Box.
Bit of an update here. As you will see from the pic below, when the extraneous pivots and metal are taken off the Spridget sourced regulator, it is VERY similar to the original Seven item.
Now fitted and working as a temporary measure with an incorrect handle.
RE: Window regulator- 1930 Mulliner Box. - by Austinsixandahalf - 09-02-2018, 08:51 PM
