  • 1 Vote(s) - 5 Average
Block Front Fixing Lug Broken
Hi Chris,
I have been in contact with a Lazer Welding specialist to do some work on a couple of 9E Blocks it will be expensive but so is a 9E Nippy Block.
No pre heating required. They can weld up valve seats in cast iron !!!
I suspect this option will be out of your price range ( I am hoping it will not be out of mine either )
In your case I would just make up a block of steel to just under the block spot face height and fit a heavier washer and enjoy the driving.
Best of Luck with it.
Block Front Fixing Lug Broken - by Chris KC - 26-06-2021, 07:09 PM
RE: Block Front Fixing Lug Broken - by Ray White - 26-06-2021, 09:10 PM
RE: Block Front Fixing Lug Broken - by Chris KC - 26-06-2021, 10:30 PM
RE: Block Front Fixing Lug Broken - by Bob Culver - 27-06-2021, 02:00 AM
RE: Block Front Fixing Lug Broken - by Chris KC - 27-06-2021, 01:23 PM
RE: Block Front Fixing Lug Broken - by JonE - 27-06-2021, 01:58 PM
RE: Block Front Fixing Lug Broken - by Chris KC - 27-06-2021, 05:35 PM
RE: Block Front Fixing Lug Broken - by dickie65 - 27-06-2021, 07:34 PM
RE: Block Front Fixing Lug Broken - by Bob Culver - 27-06-2021, 08:21 PM
RE: Block Front Fixing Lug Broken - by Chris KC - 27-06-2021, 10:15 PM
RE: Block Front Fixing Lug Broken - by AustinWood - 27-06-2021, 10:36 PM
RE: Block Front Fixing Lug Broken - by Hedd_Jones - 28-06-2021, 09:38 AM
RE: Block Front Fixing Lug Broken - by Charles P - 28-06-2021, 04:40 PM
RE: Block Front Fixing Lug Broken - by John Mason - 28-06-2021, 06:12 PM
