Using Grease Guns Properly
With modern nipples (as used in the 1960s) and an ordinary cheap gun, I find no problem. Maybe the secret is learning how to use the adjustable end, that fits onto the nipple. Too loose and grease will leak out everywhere. Too tight and the gun will not come off the nipple. It's worth having a play with the end on your gun.
Using Grease Guns Properly - by Jamie - 26-06-2021, 01:33 PM
RE: Using Grease Guns Properly - by Mick Hanna - 26-06-2021, 03:10 PM
RE: Using Grease Guns Properly - by Hugh Barnes - 26-06-2021, 03:42 PM
RE: Using Grease Guns Properly - by Howard Wright - 26-06-2021, 06:04 PM
RE: Using Grease Guns Properly - by andrew34ruby - 26-06-2021, 07:06 PM
RE: Using Grease Guns Properly - by Jamie - 27-06-2021, 12:11 AM
RE: Using Grease Guns Properly - by Bob Culver - 27-06-2021, 01:49 AM
RE: Using Grease Guns Properly - by Mick Hanna - 27-06-2021, 11:25 AM
RE: Using Grease Guns Properly - by A G Wood - 28-06-2021, 02:43 AM
RE: Using Grease Guns Properly - by Bob Culver - 28-06-2021, 07:31 AM
RE: Using Grease Guns Properly - by Colin Morgan - 29-06-2021, 10:06 AM
RE: Using Grease Guns Properly - by JohnD - 29-06-2021, 11:14 AM
RE: Using Grease Guns Properly - by andrew34ruby - 29-06-2021, 09:43 PM
RE: Using Grease Guns Properly - by Graham Barker - 30-06-2021, 10:10 AM
RE: Using Grease Guns Properly - by David Stepney - 30-06-2021, 10:18 AM
RE: Using Grease Guns Properly - by Graham Barker - 30-06-2021, 09:29 PM
RE: Using Grease Guns Properly - by A G Wood - 30-06-2021, 09:51 PM
RE: Using Grease Guns Properly - by Jamie - 30-06-2021, 10:07 PM
RE: Using Grease Guns Properly - by Jamie - 01-07-2021, 02:03 PM
RE: Using Grease Guns Properly - by Hedd_Jones - 01-07-2021, 03:33 PM
RE: Using Grease Guns Properly - by Jamie - 01-07-2021, 05:03 PM
RE: Using Grease Guns Properly - by Charles P - 01-07-2021, 07:55 PM
