Using Grease Guns Properly
Grease nipples is a surpisingly complex world with many differing standards. Some while back, I came across this company - https://www.kingfisherlubrication.co.uk/ Upon enquiry it transpired that they still manufacture and sell grease nipples that will fit our cars. I purchased a set - admittedly not particularly cheap and postage was a bit steep, but as well as the selecton of grease nipples the correct 'union' for the end of a grease gun was also provided. This was a well worth exercise, even given the expense, as the system works flawlessly..
They also have a Facebook presence, for those so inclined, and that would be an easy way to send a messge if you wished to contact them
https://www.facebook.com/kingfisherlubrication/
hth...
Using Grease Guns Properly - by Jamie - 26-06-2021, 01:33 PM
RE: Using Grease Guns Properly - by Mick Hanna - 26-06-2021, 03:10 PM
RE: Using Grease Guns Properly - by Hugh Barnes - 26-06-2021, 03:42 PM
RE: Using Grease Guns Properly - by Howard Wright - 26-06-2021, 06:04 PM
RE: Using Grease Guns Properly - by andrew34ruby - 26-06-2021, 07:06 PM
RE: Using Grease Guns Properly - by Jamie - 27-06-2021, 12:11 AM
RE: Using Grease Guns Properly - by Bob Culver - 27-06-2021, 01:49 AM
RE: Using Grease Guns Properly - by Mick Hanna - 27-06-2021, 11:25 AM
RE: Using Grease Guns Properly - by A G Wood - 28-06-2021, 02:43 AM
RE: Using Grease Guns Properly - by Bob Culver - 28-06-2021, 07:31 AM
RE: Using Grease Guns Properly - by Colin Morgan - 29-06-2021, 10:06 AM
RE: Using Grease Guns Properly - by JohnD - 29-06-2021, 11:14 AM
RE: Using Grease Guns Properly - by andrew34ruby - 29-06-2021, 09:43 PM
RE: Using Grease Guns Properly - by Graham Barker - 30-06-2021, 10:10 AM
RE: Using Grease Guns Properly - by David Stepney - 30-06-2021, 10:18 AM
RE: Using Grease Guns Properly - by Graham Barker - 30-06-2021, 09:29 PM
RE: Using Grease Guns Properly - by A G Wood - 30-06-2021, 09:51 PM
RE: Using Grease Guns Properly - by Jamie - 30-06-2021, 10:07 PM
RE: Using Grease Guns Properly - by Jamie - 01-07-2021, 02:03 PM
RE: Using Grease Guns Properly - by Hedd_Jones - 01-07-2021, 03:33 PM
RE: Using Grease Guns Properly - by Jamie - 01-07-2021, 05:03 PM
RE: Using Grease Guns Properly - by Charles P - 01-07-2021, 07:55 PM
