oily bores
First of all, I'm no expert, but I reckon my eyesight is OK...
Looking at your photo of the piston and rings I can see that the top compression ring appears to have a tapered profile as there is no apparent contact wear on the lower portion of the ring face. The next ring down appears to have a shamfer on both upper and lower edges. Could these two rings be mis placed?
Furthermore, the two oil control rings have two contact faces, one of which is slightly wider than the other, although each ring is fitted upside down relative to its sibling. The fact that you've got the gap on the upper oil control ring coincident with the hole in the piston skirt would suggest that it's not helping much with oil control.
Just my observations, I might be talking bollocks. (it's usually the case!)
oily bores - by steve davidson - 07-02-2018, 11:24 PM
RE: oily bores - by GK5268 - 07-02-2018, 11:57 PM
RE: oily bores - by steve davidson - 08-02-2018, 12:34 AM
RE: oily bores - by Colin Reed - 08-02-2018, 01:56 AM
RE: oily bores - by steve davidson - 08-02-2018, 06:08 AM
RE: oily bores - by Ruairidh Dunford - 08-02-2018, 09:44 AM
RE: oily bores - by steve davidson - 08-02-2018, 08:39 PM
RE: oily bores - by Austin in the Shed - 08-02-2018, 10:48 AM
RE: oily bores - by Charles P - 08-02-2018, 01:58 PM
RE: oily bores - by Reckless Rat - 08-02-2018, 08:57 PM
RE: oily bores - by Bob Culver - 11-02-2018, 07:58 AM
RE: oily bores - by steve davidson - 12-02-2018, 02:03 AM
RE: oily bores - by Bob Culver - 12-02-2018, 07:08 AM
RE: oily bores - by steve davidson - 14-02-2018, 07:47 AM
RE: oily bores - by Ruairidh Dunford - 12-02-2018, 10:18 AM
RE: oily bores - by AllAlloyCup - 12-02-2018, 10:53 AM
RE: oily bores - by Ray White - 12-02-2018, 02:45 PM
RE: oily bores - by Ruairidh Dunford - 12-02-2018, 03:32 PM
RE: oily bores - by "Slack Alice" Simon - 12-02-2018, 04:17 PM
RE: oily bores - by Colin Wilks - 14-02-2018, 10:22 AM
RE: oily bores - by steve davidson - 15-02-2018, 09:05 PM
RE: oily bores - by Ruairidh Dunford - 14-02-2018, 10:43 AM
RE: oily bores - by steve davidson - 27-03-2018, 03:35 AM
RE: oily bores - by JonE - 09-05-2021, 08:22 AM
RE: oily bores - by Nick Turley - 09-05-2021, 10:11 AM
RE: oily bores - by Bob Culver - 09-05-2021, 10:47 AM
RE: oily bores - by JonE - 09-05-2021, 12:27 PM
RE: oily bores - by Tony Griffiths - 09-05-2021, 12:50 PM
RE: oily bores - by John Cornforth - 09-05-2021, 09:05 PM
RE: oily bores - by Bob Culver - 09-05-2021, 09:25 PM
RE: oily bores - by Reckless Rat - 10-05-2021, 12:16 PM
RE: oily bores - by John Mason - 10-05-2021, 01:21 PM
RE: oily bores - by Ilmoro - 10-05-2021, 01:22 PM
RE: oily bores - by Reckless Rat - 10-05-2021, 01:47 PM
RE: oily bores - by JonE - 11-05-2021, 09:48 AM
RE: oily bores - by Parazine - 11-05-2021, 10:57 AM
RE: oily bores - by JonE - 11-05-2021, 11:42 AM
RE: oily bores - by Bob Culver - 11-05-2021, 05:20 PM
RE: oily bores - by Chris KC - 11-05-2021, 10:29 PM
RE: oily bores - by Chris Garner - 11-05-2021, 10:38 PM
RE: oily bores - by Bob Culver - 11-05-2021, 11:55 PM
RE: oily bores - by JonE - 14-05-2021, 10:32 PM
RE: oily bores - by John Cornforth - 15-05-2021, 09:58 AM
RE: oily bores - by Dave Mann - 15-05-2021, 10:12 AM
