  • 2 Vote(s) - 3 Average
Steering worm gear
You presumably took apart because something didn't feel right?
Cannot really tell the state of it from one close-up picture.
If you don't have a good spare, it may be worth grinding this one and see how it looks when polished a bit.
Which you do by cleaning the steering box insides, the worm and the gear thoroughly.
Smearing fine grinding paste on the worm and/or the gear.
Re-assembling the box, and working the steering wheel back and forth for some time.
Dis-assemble, inspect - and repeat.
When finished, thoroughly clean everything at least twice to remove any trace of grinding paste.
This is what you do to "re-condition" a worn steering box, if rotating the gear on its shaft doesn't work.
I have spent about 4 hours in total on one, and reckon I'm about half way through the process.
It should only take a few minutes, though, to make yours look a bit better - or not, as the case may be.
Steering worm gear - by Simon Scott - 14-06-2021, 03:31 PM
RE: Steering worm gear - by andrew34ruby - 14-06-2021, 06:06 PM
RE: Steering worm gear - by "Slack Alice" Simon - 14-06-2021, 07:06 PM
RE: Steering worm gear - by Simon Scott - 15-06-2021, 08:23 AM
RE: Steering worm gear - by Ian Williams - 15-06-2021, 08:27 AM
RE: Steering worm gear - by Simon Scott - 15-06-2021, 08:29 AM
RE: Steering worm gear - by Chris KC - 15-06-2021, 09:06 AM
RE: Steering worm gear - by Simon Scott - 15-06-2021, 01:20 PM
RE: Steering worm gear - by Steve kay - 15-06-2021, 08:23 PM
RE: Steering worm gear - by Ian Williams - 15-06-2021, 08:29 PM
RE: Steering worm gear - by John Cornforth - 15-06-2021, 08:49 PM
RE: Steering worm gear - by Bob Culver - 15-06-2021, 09:04 PM
RE: Steering worm gear - by Ian Williams - 15-06-2021, 10:11 PM
RE: Steering worm gear - by JonE - 16-06-2021, 07:40 AM
RE: Steering worm gear - by Parazine - 16-06-2021, 08:05 AM
RE: Steering worm gear - by John Cornforth - 16-06-2021, 08:19 AM
RE: Steering worm gear - by Simon Scott - 16-06-2021, 08:42 AM
RE: Steering worm gear - by Parazine - 16-06-2021, 08:52 AM
RE: Steering worm gear - by Reckless Rat - 16-06-2021, 09:37 AM
RE: Steering worm gear - by Simon Scott - 07-07-2021, 09:19 AM
RE: Steering worm gear - by Ally Monce - 13-07-2021, 04:34 PM
RE: Steering worm gear - by JonE - 09-11-2021, 05:45 PM
RE: Steering worm gear - by David Stepney - 09-11-2021, 08:45 PM
RE: Steering worm gear - by Parazine - 09-11-2021, 11:41 PM
RE: Steering worm gear - by squeak - 10-11-2021, 04:12 AM
RE: Steering worm gear - by Dennis Nicholas - 10-11-2021, 01:02 PM
RE: Steering worm gear - by Tony Press - 10-11-2021, 10:31 PM
RE: Steering worm gear - by Bob Culver - 10-11-2021, 10:44 PM
RE: Steering worm gear - by Alan - 10-11-2021, 11:10 PM
RE: Steering worm gear - by Dennis Nicholas - 15-11-2021, 04:08 PM
RE: Steering worm gear - by Tony Press - 16-11-2021, 04:24 AM
RE: Steering worm gear - by Dennis Nicholas - 21-11-2021, 07:26 PM
RE: Steering worm gear - by Colin Morgan - 01-12-2021, 10:40 PM
RE: Steering worm gear - by Ivor Hawkins - 02-12-2021, 01:15 PM
